Generic Threat Model
The Generic Threat Model discusses an abstract physical Secure Partition and captures service independent security related information like assets, threats, and mitigations.
This model serves as the foundation for assessing the security of any specific deployment involving one or more Trusted Services.
Target evaluation
In this threat model, the target of evaluation is the S-EL0 SPs part of the PSA RoT hosting a “generalized” trusted service.
This evaluation is based on the following assumptions:
  • The implementation is based on the FF-A standard.
  • Trusted boot is enabled. This means an attacker can’t boot arbitrary images that are not approved by platform providers.
  • Each trusted service is running in an S-EL0 secure partition. Access to memory and hardware is controlled by the SPM based on the FF-A manifest or FF-A framework messages.
  • Components running at higher privilege levels than S-EL0 are to be inherently trusted. (I.e. the SPM).
Data flow diagram
The data flow diagram visualizes the connection between components and where the data flow crosses security boundaries.
../../_images/generic-data-flow.svg
List of generic data flows
Data flow
In scope
DF1
Trusted Service interacts with NWd client directly.
Yes
DF2
Trusted Service interacts with NWd client through SPM.
Yes
DF3
Trusted Services interact through SPM.
Yes
DF4
Trusted Service logs debug information.
Yes
DF5
Trusted Services interact directly.
Yes
DF6, DF7
Trusted Services interacts with shared hardware.
Yes
DF8
Trusted Service interacts with dedicated peripheral interface.
Yes
DF9, DF10
Trusted Service interacts with shared, external hardware.
Yes
DF11
Trusted Service interacts with dedicated, external hardware.
Yes
DF12
NWd interacts with more privileged software.
No
DF13
FF-A manifest and other data is handed over to a Trusted Service
No
DF14
Trusted Service interacts with dedicated, physically protected hardware.
Yes
It is worth highlighting two different dataflow types between the service and its clients:
  1. Direct communication through shared memory. DF1 and DF5 represents this type of communication and it may be sensitive to TOCTTOU attacks. See threat 10 below.
  2. Indirect communication through registers. DF2 and DF3 represents this type. This type is more secure and less performant.
Trust boundaries
List of trust boundaries
Trust boundary
TB1
Trust boundary between TEE and normal world.
TB2
Trust boundary between higher privilege level SW and Trusted Services.
TB3, TB4
Trust boundary between trusted services.
TB5
Trust boundary to physically accessible external hardware.
Assets
The above dataflow identifies the following generalized assets.
Assets
Asset
availability
Availability of a trusted service to clients.
code execution
Code or code flow of a trusted service.
sensitive data
Data that an attacker must not tamper with. These include device identity key, Initial Attestation Key, Protected Storage Key, UEFI variables, TPM event log.
sensitive hardware
Hardware that an attacker must not be tamper with. Examples are control interface of storage medium, true random number generator, crypto accelerator.
Attackers and threat agents
This section identifies the generalized stakeholders interacting with secure services.
Attacker/Threat agent
In scope
NSClient
Client executing in the normal world.
Yes
SClient
Client running in SWd.
Yes
HPComponent
Components running at higher privilege level than the trusted service.
No
AppDebug
Physical attacker using debug signals to access resources.
Yes
PhysAcc
Physical attacker having access to the external device communication bus and to the external flash communication bus using common hardware.
Yes
AdvPhysAcc
Attackers who are able to use specialist hardware for attacks that require irreversible changes to the target system (e.g., “rewiring” a chip using a Focused IonBeam FIB workstation).
No
Threat Priority
Threat priority calculation is based on Common Vulnerability Scoring System (CVSS) Version 3.1. The threat priority is represented by the Severity Rating Scale calculated from the CVSS score of each threat. The CVSS score is calculated using the Vulnerability Calculator.
For each threat the priority and a link to CVSS calculator capturing the calculator settings will be listed.
Threat Types
In this threat model we categorize threats using the STRIDE threat analysis technique. In this technique a threat is categorized as one or more of these types: Spoofing, Tampering, Repudiation, Information disclosure, Denial of service or Elevation of privilege.
ID
GEN1
Information leak via debug logs.
During development it is common practice to help understanding code execution by emitting debug logs.
Data flow
DF4
Asset(s)
Sensitive Data
Threat Agent/Attacker
AppDebug
Threat type
Sensitive information may get to unauthorized people. Information can potentially help compromising the target or other systems.
Scoring/CVSS
Medium, 4.6 CVSS:3.1/AV:P/AC:L/PR:N/UI:N/S:U/C:H/I:N/A:N
Log messages are put to “verbosity categories”. Release builds limit printed log messages to “error” category.
Mitigation in place
yes
ID
GEN2
An attacker can tamper with sensitive data and execute arbitrary code through hardware-assisted debug interface.
Data flow
N/A.
Asset(s)
Sensitive Data, Code Execution, Sensitive Hardware
AppDebug
Threat type
Information disclosure, Tampering
An attacker may modify sensitive data and alter device behavior and thus compromise the target or other systems.
Scoring/CVSS
Medium, 6.8 CVSS:3.1/AV:P/AC:H/PR:H/UI:R/S:C/C:H/I:H/A:H
Hardware platform specific means to disable or limit access to debug functionality.
Mitigation in place
yes
ID
GEN3
An attacker can perform a denial-of-service attack by using a broken service call that causes the service to enter an unknown state.
Secure and non-secure clients access a trusted service through FF-A calls. Malicious code can attempt to place the service into an inconsistent state by calling unimplemented calls or by passing invalid arguments.
Data flow
DF1, DF2, DF3, DF5
Asset(s)
Availability
NSclient, SClient
Threat type
Denial of service
The service or the whole system may temporarily or permanently enter an unusable state.
Scoring/CVSS
Medium, 6.8 CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:N/I:L/A:H
The service must validate all inputs before usage. Input validation shall be checked during code review and by testing.
Mitigation in place
yes
ID
GEN4
Memory corruption due to memory overflows and lack of boundary checking when accessing resources.
Allows an attacker to execute arbitrary code, modify memory content to change program flow.
Data flow
DF1, DF2, DF3, DF5
Asset(s)
Code execution, Sensitive Data, Denial of service
SClient, NSClient, HSComponent
Threat type
Tampering, Information disclosure, Elevation of privilege, Denial of service
Malicious code might be executed in the context of the compromised service. Leakage of sensitive data.
Scoring/CVSS
High, 8.4 CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:H/I:H/A:H
The service must validate boundaries and sanity check incoming data. Validation shall be checked during code reviews and by testing.
Mitigation in place
yes
ID
GEN5
External devices connected to the system storing sensitive data. An attacker could eavesdrop external signals.
Data flow
DF9, DF10, DF11
Asset(s)
Sensitive Data
Threat agent/Attacker
PhysAcc
Threat type
An attacker may get access to sensitive data, could tamper with sensitive data, or could attack the service using the external device by injecting malicious data, which could lead to malfunction or execution of malicious code.
Scoring/CVSS
Medium, 5.9 CVSS:3.1/AV:P/AC:L/PR:N/UI:R/S:U/C:H/I:N/A:H
When designing the use case, storage services must be assessed to understand which protection type they can implement (integrity, authenticity, confidentiality, rollback-protection). Sensitive data must be categorized and mapped to the storage service which can provide the needed protection.
For example integrity can be safeguarded by using checksums. Authenticity by using digital signatures. Confidentiality by using encryption. Rollback protection by using nonce values.
Mitigation in place
yes
ID
GEN6
State of external devices connected to the system might be modified by an attacker.
This includes modifying signals, replacing the device, or modifying device content.
Data flow
DF9, DF10, DF11
Asset(s)
Sensitive Data, Denial of service, Code execution
PhysAcc
Threat type
Tampering, Denial of service, Code execution
An attacker could tamper with sensitive data, or could attack the system by injecting malicious data, which could lead to malfunction, execution of malicious code, or using old state with known vulnerability.
Scoring/CVSS
High, 7.3 CVSS:3.1/AV:P/AC:L/PR:N/UI:R/S:C/C:H/I:H/A:H
For example integrity can be safeguarded by using checksums. Authenticity by using digital signatures. Confidentiality by using encryption. Rollback protection by using hardware backed nonce values.
Mitigation in place
yes
ID
GEN7
Invalid or conflicting access to shared hardware.
Data flow
DF6, DF7, DF9, DF10
Asset(s)
SClient, NSClient, HPComponent
Threat type
Tampering, Information disclosure, Denial of service, Code execution
A trusted service relying on shared hardware usage might get compromised or misbehaving if other stakeholders affect shared hardware in unexpected way.
Scoring/CVSS
High, 7.0 CVSS:3.1/AV:L/AC:H/PR:L/UI:N/S:C/C:L/I:L/A:H
Access to peripherals must be limited to the smallest possible set of services. Ideally each peripheral should be dedicated to a single trusted service and sharing of peripherals should be avoided is possible. If sharing can not be avoided, a strict handover process shall be implemented to allow proper context switches, where hardware state can be controlled.
Mitigation in place
yes
ID
GEN8
Unauthenticated access to hardware.
A trusted service relying on hardware usage might get compromised or misbehaving if hardware state is maliciously altered.
Data flow
DF6, DF7, DF9, DF10
Asset(s)
Threat type
An attacker may get access to sensitive data of might make a trusted service or the system enter an unusable state by tampering with hardware peripherals.
Scoring/CVSS
Medium, 6.4 CVSS:3.1/AV:L/AC:H/PR:H/UI:N/S:U/C:H/I:H/A:H
Access to peripherals must be limited to the smallest possible set of services. Ideally each peripheral should be dedicated to a single trusted service, and sharing of peripherals should be avoided is possible. If sharing can not be avoided, a strict handover process shall be implemented to allow proper context switches, where register values can be controlled.
Mitigation in place
yes
ID
GEN9
Unauthenticated access to sensitive data.
Data flow
DF1, DF2, DF3, DF5
Asset(s)
Threat type
A trusted service may manage data of multiple clients. Different clients shall not be able to access each other’s data unless in response to explicit request.
Scoring/CVSS
Medium, 6.8 CVSS:3.1/AV:L/AC:L/PR:N/UI:N/S:U/C:H/I:L/A:N
Trusted services must implement access control based on identification data provided by higher privileged components (i.e. FF-A endpoint ID).
Mitigation in place
yes
ID
GEN10
Time-of-Check to Time-of-Use (TOCTTOU) attack trough shared memory.
Data flow
DF1, DF5
Asset(s)
Sensitive Data, Code execution, Availability
SClient, NSClient
Threat type
Tampering, Information disclosure, Denial of service, Elevation of privilege
An attacker may cause incorrect operation of the service, and thus:
  • make the system enter an unusable state,
  • breach logical isolation boundary within the trust domain of the service and impersonate other client
  • execute unauthentic code.
Scoring/CVSS
High, 7.4 CVSS:3.1/AV:L/AC:H/PR:N/UI:N/S:U/C:H/I:H/A:H
  • The Trusted service must copy data to a private buffer when executing TOCTTOU sensitive operation.
  • The service implementation must not read the input buffer multiple times.
Mitigation in place
yes
Source file of the Data flow diagram. Please use the yEd for editing. ./generic-data-flow.graphml
Copyright (c) 2022-2025, Arm Limited and Contributors. All rights reserved.
