PSA Storage SPs
This document uses the term PSA Storage to refer to PSA Protected Storage SP and PSA Internal Trusted Storage SP. From Trusted Services perspective, there are only subtle differences between the two. The two services implement a slightly different API, and ITS must not use the PSA Crypto SP for cryptographic operations to avoid circular dependency. From security perspective the two SPs are the same.
Scope of evaluation
This assessment makes the following assumptions:
  • The PSA Storage service is deployed to a dedicated S-EL0 SP, and its execution context is isolated from other services, using TrustZone.
  • The SP may own the storage HW or it may rely on another service for non-volatile storage (e.g. the Block Storage SP).
  • No shared storage device will be used. In such a scenario, the shared device will be assigned to another SP which provides a service level API. A good example is the Block Storage SP.
  • The SP will use the Logging SP, or the FF-A logging API provided by the SPMC.
Assessment Results
This section specializes the threats identified in the Generic Threat Model for the storage service where needed. Threats not listed here are mitigated as described in the Generic Threat Model.
  • GEN05 “External devices connected to the system storing sensitive data.”
    This threat is in scope if the platform uses an external device as the non-volatile storage for the service. The service must protect data in transit at DF9 and DF11.
  • GEN06 “State of external devices connected to the system might be modified by an attacker.”
    This threat is in scope when the platform relies on an external device for non-volatile storage used by the service. To mitigate the risk, the service must implement platform-specific measures to protect the data.
  • GEN07 “Invalid or conflicting access to shared hardware.”
    This threat is out of scope due to the scope of evaluation.
  • GEN08 “Unauthenticated access to hardware.”
    This threat is out of scope as shared usage of hardware is excluded by the scope of evaluation.
  • GEN09 “Unauthenticated access to sensitive data.”
    The PSA Storage SP isolates clients at FF-A level and each FF-A endpoint is isolated to its own namespace.
    If the selected storage backed relies on another service like the Block Storage SP, the backend service must implement access control and client isolation too.
  • GEN10 “Time-of-Check to Time-of-Use (TOCTTOU) attack through shared memory.”
    PSA Storage code will not read the input data multiple times and thus this threat is mitigated.
Copyright (c) 2025, Arm Limited and Contributors. All rights reserved.
